Well I was pretty much thinking the same as you.
If I have the chance to get automatic promotion then for sure I'll take it.
For a team that was expected a mediocre mid-table position in the Championship, to actually come second (or possibly win it) will do wonders for the club, it's fans... and of course my managerial career (
It'll also give me a little extra time to spend money on signings and snap up some free transfers... but the playoffs mean it'll all be a bit uncertain.
I wouldn't want to splurge on some players knowing that
a) I may not be in the Premiership next year and couldn't afford to keep them in the Championship
or
b) If relegation was imminent from the Premiership, would those players still want to play in a Championship side?
I have an advantage with Swansea though, our Stadium is a 20,000 all seater and is a new build as well. So it's a pretty decent size and I wouldn't have to worry about spending millions to build a new one to fit new fans in.
I kept the same tactic I created at the start of the season, but altered it slightly after playing a few games with SCM's 4-4-2 tactic.
It's now a mixture of what I originally was using, and his.
Depending on the opposition I make the wingers more adventurous and do forward runs more often.
I play two CM fielders.
One runs forward into a CAM being a more creative player. Looking to play the ball on for the forwards, or strike from distance if need be.
The other drops off into a CDM role, picks up the scraps from the defence and helps them out when need be. He comes forward and bags the odd goal here and there too.
I kept the idea I noticed in SCM's tactics where one striker drops back slightly and plays the ball on for the other striker.
The guy that drops off is usually a bit slower and slightly stronger with better passing ability and awareness and ability to open the game up.
Whilst the player that stays up is quick, has the ability to beat defenders with his dribbling and normally the better finisher of the two.
or
