18 Nov 2007 at 11:04 #1 buzzby buzzby Associate Joined 24 Oct 2002 Posts 656 Pretty much as title I think the camera can take the 4gb cards but want to make sure before a buy one.
18 Nov 2007 at 11:11 #2 Thebug Thebug Associate Joined 17 Feb 2007 Posts 1,987 Location Walsall My D40 can so the D40x should do as well Edit: Yes it does - should say SDHC on it http://nikoneurope-en.custhelp.com/...nBfc2VhcmNoX3RleHQ9ZGNhcmQx&p_li=&p_topview=1 Last edited: 18 Nov 2007
18 Nov 2007 at 12:13 #3 Vertigo Vertigo Soldato Joined 28 Dec 2003 Posts 16,627 You can get 4GB non-SDHC cards you know, should anything have a problem with SDHC. Anything above 4GB will be HC though.
18 Nov 2007 at 16:11 #4 TrUz TrUz Associate Joined 18 Oct 2002 Posts 2,154 Location Leicester, UK Vertigo1 said: You can get 4GB non-SDHC cards you know, should anything have a problem with SDHC. Anything above 4GB will be HC though. Click to expand... Are you sure? I though anything above 2GB was SDHC. TrUz
18 Nov 2007 at 21:24 #5 Vertigo Vertigo Soldato Joined 28 Dec 2003 Posts 16,627 Nope, you can get 4GB non-SDHC cards as I use two of them in the car, which doesn't support SDHC.
19 Nov 2007 at 02:21 #6 robmiller robmiller Soldato Joined 26 Dec 2003 Posts 16,522 Location London But the point's moot anyway, because the D40 and D40X (and D80 too) support SDHC
19 Nov 2007 at 07:51 #7 buzzby buzzby Associate OP Joined 24 Oct 2002 Posts 656 robmiller said: But the point's moot anyway, because the D40 and D40X (and D80 too) support SDHC Click to expand... Thats the answer i needed. Thanks
