I have a Silverstone TJ07 on the way, my next task is watercooling.
I have a Asus Maximus SE mobo, it has a preinstalled northbridge block. I also have OCZ FlexXLC RAM that you can watercool but it probably isn't worth the effort. has anyone done this with 4 sticks? my loop will probably be full as it is.
I am looking to cool a quad core, 8800GT, and the NB. will 1 pump be ok and what size radiator will I need?
Ideally I would like a 220 as it will fit inside but if needed I can fit a 320 rad.
Also what size tubing is the best? is there an advantage going for 1/2" tubing when the northbridge block seems so small?
