*Unreal Tournament III*Thread :o) Game Pics & Performance.
9 out of 10 people know the website you all refer to as Jersey and 1 person has said there name. tsk tsk
RTM if you want brownie points, otherwise let the moderators do this job.
Mine is still processing, which is a bit annoying as i hoped to have it today, obviously its not to be.
Can't wait for this, that screen shot looks great. Looks like an classic UT map.
I loved UT2004, one of the best imo. :)
Could some one tell me how this plays on an x1900 xt? I haven't had a chance to have a play yet so am anxious as I'll put it on my xmas list if it is.
Runs great on a 1950, so a 1900 can't be far behind. The demo for me runs very smooth if the demo is anything to go by. But you should check for sure via the demo.
Apparently there's an X-Fi crash problem according to the epic forums. And if your demo crashes, then your retail will also crash. If you disable the X-Fi then it should run fine hopefully, i don't know just going off on what i read.
It also reads on there that it doesn't like the 8800 gt(s), which is a bit silly since it's meant to be tweaked for nvidia cards. The suggestion for this was to tweak ** ini file in your documents, or try it in window mode.
Pfff, i can wait a day, patience is a virtue right? See you on the server, pal!
Its been here since yesterday, unfortunately uni then work took it out of me so I havent been able to install until now! Will be interesting to see HOW GOOD the graphics become! I may give vista a go also just out of curiosity
It's obviously slower on vista depending whether u're running 32bit or 64bit, the 64bit will have to emulate 32bit to run ut3.
But you'll be looking forward to really high rez textures and of course more content, and in fact so much so your degree may just be in danger!
Well iv just played it and performance/visual quality on XP is pretty much identical on my HD3870! Not a bad thing since the avg framerate is around 85-90fps!
The Story Mode/Campaign has 4 difficulty levels im playing it on Hard at the moment, not intense yet! They basically have put some story movies in between all the happenings to try and structure something! The cinematics are impressive though and the game is running in a nice little package! Very intense and the co-op Story mode is actually quite the bonus, will be worthwhile running some lan or internet story mode for sure :D
Gonna try it with Vista later on in the afternoon :)
Apparently the AI blows and becomes a liability when you're trying to win since they'll give away the most kills and hog the vehicles in silly places, or hold onto the orb and not use it?
