My machine, well, tis poo, well the case is anyway. When I turn it on in thew morning or whatever, it makes a lot of noise. I cant tell wether its the Hiper PSU or the 120mm fan on the case? its a sorta 'wooom woooom woooom' sound, lika  fan not quite rite, but whenever I look insode and fiddle, all I can tell is that both the 120mm and the PSU make noise, but none major loud? Are Hipers known to be loud aswell as problematic?
		 ) so Im going to go for a new GFX card and hopefully a cheap new case first. If the PSU is still the problem then Im sure I can find £60 from my savings to replace it.
		 it doesn't mate any noise
		 The loudest things in my pc is the hard drives, other than that its pretty quiet. I have a ThermalTake Soprano case
