3x 74gb Raptors
Permabanned
31 May 2005
South Yorkshire
Will be mine come the middle of the week - it was meant to be 1 more to complement the single I've already got - I'm running low on space so was going to RAID0 them.
However, I'm now going to be getting 2 extra so my question is, what's the best RAID config to put 3 drives in? Whichever configuration, it'll be partitioned into a 10gig for XP and whatever else is left for games, apps, the odd bit of encoding etc.
Motherboard is an ASUS Nforce 650i SLI and I've got 3 other IDE drives (2x160gb and 1x200gb) purely for storage.
I dont believe in partitions apart from dual Booting OS.
Some claim it saves a reinstall of all Games/APP's if Windows dies, well most wont run unless reinstalled as not written to Windows Reg and folders.
I would Raid0 all 3 and run as 1 big HDD, and always back up as anyone should do be it Raid or non Raid.
External 500+GB HDD's are cheap as chips these days.
Not true in my experience. Only had one game so far that didn't want to run (Hitman Blood Money). Re-installing it took 20 seconds anyway because all of the files (except for a select few that it needed) were already on the disk, so it didn't have to copy them all across again.
I'd always recommend partitioning. If not for the sake of not having to re-install, but it keeps the drive a bit tidier and makes defragging easier.
Thats your choice m8, I have plenty Games and APP's and I mean DOZENS that will need reinstalled to even run.
Back Up is the answer, then you do not need worry.
The days of FAT32 are over, we have Big Stable Partitions now.
I use 2 partitions, if windows needs reinstalling no need to mess around with programs as I can just restore the old registry after reformatting.
The partitions thing is just personal preference - it's just the way I'm used to and I have my own directory structure that works better having my OS, games/apps and storage/backup in certain places. I think I've just grown comfortable with it being that way and don't really want it to change - regardless of any positives or negatives.
Looks like RAID0 is the way to go then - I did briefly look at RAID5 but couldn't really see any benefits.
Lol, thats exactly what I do not do as many APP's need near enough a full install. (my APP's anyhow).
I just keep a back up on the 500GB ESATA HDD.
Applications yes, but I've not come across very many games at all that haven't worked after a Windows re-install. Only thing you tend to lose is the shortcut icons/Start menu entries, providing you back up your Documets/Profile folder appropriately. Whether or not that starts to change though, I don't know. Hopefully not.
I haven't personally found anything that requires a reinstall, not a single program needed reinstalling after my last reformat. You must use some unusual software.
1 has arrived today.
I get the feeling this is quite a stupid question but here goes.
Can I build a 2 disk array today and do what I need to do OS wise, and add the third into the array tomorrow when the other one comes?
Depends on the RAID controller. Quite a few will support Online Capacity Expansion but all that will do is expand the array, you'll still need to extend any partitions you have on the array manually.
any chance you could run hd_tune on the raid1 array when you get all 3 drives. I wanna see whether its worth me doing the same or just installing the OS on my raid6 array instead :P
I've just this last half hour booted into a 2 disk RAID0 array. My third drive should be coming either tomorrow or monday - the nforce controller allows me to add the third drive to the array when it arrives.
HD Tune gives me:
Minimum 94.4 MB/sec
Maximum 129.6 MB/sec
Average 102.2 MB/sec
Access Time 7.5ms
Burst Rate 109.1MB/sec
CPU Usage 2.7%
Will do the 3-disk array and post as soon as possible.
Mr Cheese - yeah they're both 8mb.
Got the third disk sitting at the side of me waiting to be squeezed into the last space in my drive bays.
