Swiftech MCP655 Pump
ThermoChill PA120.3 Triple Radiator
3/8 ThermoChill 1/2 Barb x 2
Heavy Duty Hose Cutters
EK FC8800 8800GTX Full Cover GPU Waterblock - Acetal Top
D-Tek FuZion Accelerator Nozzle Kit
Water Wetter 20ml
EK Multioption RES 250 Rev.2
D-Tek FuZion Universal CPU Waterblock
Zinc Plated Worm Drive Hose Clip for 1/2 Tubing
Specialtech 1/2 Hi-Flex Tubing
Xilence Red Wing 120mm Quiet Fan
Zalman ZM-MFC1 Plus Fan Controller - Black
Arctic Silver Ceramique 2.5g Tube
Arctic Silver 5 3.5g
Akasa TIM Cleaning Solution
Aquacomputer ATX PSU Tester
That is everything ordered now
I have read that ceramique should be used on memory on GPU, but some people have said to mix with artic silver? Is that worth doing?
I will post some pics once all built. Should be fun. Still not sure where to place radiator though, will either be on back of case of top of the case, but inside. I am guessing mounting it on the back of the case will be best for getting rid of heat.
