Replacing a psu fan
21 Oct 2002
Did a bit a stupid thing today. To see how noisy the fan is on my PSU i stuck a pen in the fan to stop it for a second or two. Unfortunatly one of the blades shot off lol!! So are these fans the same as your average case fan and can i just fit a new one or is voltage different?
Cheers for helping this stooooopid individual!
Indeed, them caps can give a nasty shock.
If you do proceed leave it a good few days to let the caps discharge and be very very careful.
Rob
Don't even think about it.
The capacitors in you PSU hold enough change long after you turn it off to kill you dead. Twice.
Fraid your going to have to buy a new one. :(
If you're that stupid, I think you'll die several times trying to replace the fan.
Its not hard to change a fan in a PSU, so long as you are careful. I've modded countless PSU's in the past.
seconded:)
just don't touch ANY of the caps inside
personally i use rubber gloves.make sure the psu has been discharged(turn off at mains then press power button on case)
but the fans usually have a two wire connection so you may need to either solder or twist the cables etc
another way is to use either a 3pin or 4 pin fan of sufficient speed to cool your psu,with the wires run out side of the psu case and connected to one of the psu molexes or 3 pin adapter or mobo connector if you get my drift
Go for it. Most modern PSU circuitry will discharge the caps when power is removed. Even if it doesn't you'll be ok as long as you don't go touching the protruding leads on the underside of the PCB.
As said before, as long as you don't touch any of the capacitors its not that hard a task however make sure you ground youself before you touch it. You maybe able to change the fan but you don't want to ruin the psu after.
What make / model is it?
