Music Libarys
Nope, sometimes I will load up Windows Media Player, and when I go to search for some songs, The listing for the song will be there, but It will then say that it can not find the file. I dont change or move any file/folder
somethings wrong, for all of them to do the same, can't be software related. I have 12k music files and no software does that unless I change file names or move something about.
If it was just wmp doing it then, yeh but as winamp and music monkey has done it as well. Points to another problem. Not sure what.
You gone through and re tagged any music?
foobars rubbish as it's impoosible to set up how you want it, unless you can script. Far to much effort. If you can find a skin you like it's nice. But I couldn't.
Yet another vote for itunes (with a 100Gb Library). The latest WMP is improved but just not up to itunes standards yet. Foobar sounds great but is so damn complicated (very needlessly).
I've just switched to iTunes from winamp and its bloody brilliant.
Its taking me ages to set up all my ID3 tags as not all my mp3's were set up properly but once they are all done i'm looking forward to having some control over them.
Ive never had any problems with it either in terms of libraries.
Me neither, think the OP might be changing his music folder names/directories.
All it takes is to open the Media Library and select "rescan watch folders" and then select "delete missing files" as well.
The latest winamp is sexual too.
