- 13 Nov 2007
Bought this game yesturday after hearing its decent reviews etc. However, my pc spec isn't the greatest but i was hoping that it would run slightly better than it does (AMD64 3700+ @ 2.8ghz, 2GB RAM, x1950 pro 512mb, clean XP)
Got the post filtering on the lowest, 1280x1024, 75% screen rendering, and the two graphics options below set to 2 out of 5. No aa or af using cat 7.11. The game runs at around 35fps most of the time, but stutters like mad at the start. The game also looks so awful at low settings. It looks worst than UT2003 did on the same settings!
Any suggestions as to tips or tweaks? At the moment its pretty much unplayable.![]()
Check these links:-
http://forums.beyondunreal.com/showthread.php?t=191933
http://forums.epicgames.com/showthread.php?t=580778
Also check Tweak Guides as one poster already mentioned.
. All my other games are fine, this is really the only game i've had problems with under vista so far.
. Although there is that 'multiplayer' campaign thing which I haven't tried.
