Does that clock pass crysis gpu benchmark test ?
Also have you got rivatuner installed i have a bfg oc and max shader seems to be 1728 if i am setting on rivatuner and use ati tool to scan i get no errors but i so see corruption on the 3d image if i uninstall ati tool it can clock higher think there's some issues going on here.
I'm needing something to monitor temps, as I have had a few crashes playing Bioshock, but that could be the 500w giving up....
) so if I can get the RAM sinks to stay put, was thinking thermal epoxy...I'll give it another stab, and if it doesn't come quietly then i'll chuck those monging plastic clips in the bin.
