Case is the p182 so three case fans. Think i will reseat it later as first time around it was sliding around a bit. Will check back in later![]()
most definitely outside
Worth changing the stock fan to something different? Installed it yesterday and im getting load temps of almost 80c (quad at 3.2ghz) with the fan set to around medium speed.![]()
Well redone everything, getting load temps of around 70c for 2 cores 73c for the other two. Can't say im too impressed, the cpu ihs isn't perfectly flat but its very slight to how much its off. Really can't be arsed to lap it either. Suppose i'll just make do with things how they are.
Gerad I think Boney did not read carefully and think you already have a Tuniq tower as he asks what speed u have the fan on it.lol.
You should get a tuniq mate, will reduce temps loads!
Something definitely isn't right there, don't know what it could be if you've followed the guides correctly.![]()
Could be to do with my pos asus p5k, the voltage at the minute is up at 1.51 or so for the quad becuase of the massive v-droop on this board.
Air cooling though...i dunno it just never seems to work for me, i always read about people getting these great temps, i get the exact same setup and my temps always seem to be much higher. Dunno what the reason is, im not overdoing thermal paste or anything.
