Console Related Brain Teaser
23 Feb 2006
croydon,surrey
just bridge to the pc not the router.my 360 will only work online if my pc is connected to pc so guessing it just piggybacks the pc connection.when its connected up just registers as local lan connection on my pc.
Permabanned
OP
29 Sep 2006
yeah the PC picks up the LAN connection, but its as if its obtaining the same IP address, although its set to find one automatically....
18 Oct 2002
London
hi there,
you dont need any of this bridge stuff, just set the ip maunually of the xbox, enable ICS on your wireless connection. When you enable it here will be a tab at the end of the connection properties that has details like which connection to share the internet with.
Permabanned
OP
29 Sep 2006
hi there,
yeah i get that far - do i select all, like DHCP etc
