3 HD installed Vista only see's 1
2 Nov 2007
Lo guys ive installed 3 HD's into my system in the bios the PC see's them, aswell as when i was installing vista 64, now ive got the OS up and running my 2 other HD's are gone from my computer Vista fails to see them there. As far as i no there powered and linked to the mobo due to the bios seeing them there..
Anyone tell me how to get vista 64 to now see my 2 other HD's
Control Panel > Administrative Tools > Computer management
Goto Storage and then Disk Management. They will be under there. you will need to make them active.
Thxs very much for the help, it seems vista 64 is a bit of a pain in the butt:(
Spending my sunday trying to fix my fresh install
Hey Roeg1, just to clarify, the problem (It's not really refered to a problem as such :p) that you were experiencing has nothing to do with Windows Vista. Even if you had installed Windows XP, you would have come across this as you have done with Windows Vista. Glad it's sorted though. :)
But that would be going against the trend of hating Vista! We can't be having that.
