Most critics disagree with you.
Heck I just got myself a new 8800GT and even that struggles on High/Medium at 1680x1050 with no AA. Fine most of the time but once you hit the ice part of the game it becomes a slide show at 5fps. Then the second you leave the ice it's fine again. Something very funny going on with the ice rendering.
for me running E6750 at 3.2ghz and x1900xt i can run it fine (25 - 40fps) at 1680x1050 with all on medium and post processing on high, looks rather good. So i'm confident with a new video card it will be really nice.
This is rubbish though, I put it on all low and it's still all laggy![]()
http://www.nvidia.com/object/winxp_169.09.html
Try those.
Be sure to completely remove your current drivers, using driver cleaner maybe.
And have you done any of my others suggestions?
You need a custom config, read the tweaktown guide. The game plays well enough on a x1950pro imo
Dont play it on vista
Have you actually tried it on low? The original Doom looks better. Things were popping up all over the place when you walk forward.
Absolutely struggling to even play this, it was okay before but now (im at the school level) it's unplayable, it just lags consantly and freezes all of the time so in a combat scenes it's like watching a security camera, freeze lag can't even play it. Put all settings to medium and it's still the same. Specs:
Geforce 7900 GTO 512MB
2GB Corsair
3.4GHZ P4 X2
2x250GB HD's
I even defragged the drive but still the same crap, I guess I'll try putting it on all low and seeing if it still does it.
Give the demo a try, it ran about the same as the full game, performance wise for me.Nope, despite being a massive Far Cry fan I haven't bought Crysis yet due to all the horror stories about performance. I only have a 3.2ghz C2D with GTS320 so I'm waiting until I've got something with a bit more grunt (8800ultra-SLI speed or greater) before getting it.
Just seems common sense to me that if you are unhappy with performance in a game, you lower the settings and see how you fare with that.
I will probably try the demo at some point, but due to a lot of other quality titles doing the rounds I haven't really felt the need (for example I bought Bioshock a couple of months back and haven't really got very far in yet).
Also I have a TFT monitor so don't want to use less than native resolution (1680x1050). AA disabled is fine with me but even then judging by benchmarks I need more power to keep the framerate up around the level I find playable (min [not average] fps of 45+).
