3/8 on 1/2 barbs be a nice tight fit. thats what I have
Same here, just done it and it's much neater and I couldn't tell any temp difference.
i agree, very useful as well if your using a D-Tek block as clamps are bit fiddly to fit the barbs. 3/8 no clamps required due to the tight seal.
Forgot to mention the D Tek had hell of a job with 1/2" but the 3/8" is so much better with the D Tek.
speaking from a purely geographic perspective, the bigger the tubing, the less resistance there is, and the faster the water can flow , = more effective cooling
...but also the bigger the tubing the more mass the pump has to move, meaning greater head loss as well as a lower flow rate.
The effect will not be noticeable with the tubing we are discussing in 'standard' builds.
