10mm or 1/2 tubing?
22 Oct 2006
I'm currenty planning my next build.
Just trying to work out - 10mm compression fittings? or 1/2 barbs?
I know 10mm will give me tighter bends but will it give me much more?
Or is 1/2 much better?
I'm currently using 1/2.
Temperature wise there is very very little difference if any at all...
To most people 1/2" tubing looks better though I have seen some very nice 10/8mm setups. If you are new to idea of watercooling then 10/8mm is often seen as the safer option (if used with compression fittings).
Lastly, decent 1/2" hose will bend better than 10/8mm... not the other way round.
The 10mm tubing is easier to work with and takes up less space - I used to swear by my 1/2 inch stuff and belittled friends who 'only' had 3/8ths - but with modern pumps it makes no difference to the temps, so go with what works for you. I know if I ever go back I'll be going for the thin stuff - it's no the size but what you do with it etc... :p
10mm hose has an 8mm bore which is quite a lot smaller than 1/2" (12.6mm bore).
Go for 3/8" (9.5mm bore). It's a good compromise between bore size for ggod flow and flexibility in bends without kinking.
I use Swiftech norprene 3/8 tubing. It's very thin walled and can bend really tightly, with smart coils, without kinking.
It's a shame that it's not clear though.
Forgot to mention the D Tek had hell of a job with 1/2" but the 3/8" is so much better with the D Tek.
The one and only bad point to the d-tek block , i am hoping it will be abit easier with 7/16" tubing which i am going to use in my re done loop .
I was pleasantly surprised with the outcome of using 10/8 waterchill tubing and compression fittings, can make fantastically compact water cooling setups with it.
Jokester
speaking from a purely geographic perspective, the bigger the tubing, the less resistance there is, and the faster the water can flow , = more effective cooling
...but also the bigger the tubing the more mass the pump has to move, meaning greater head loss as well as a lower flow rate.
That use to be true to an extent, but the new pumps make it moot. Tube sizing (1/2" down to 10mm) makes no difference to performance anymore - if you don't believe us go and track Down Cathar on XS as have a look at his research. ;)
The effect will not be noticeable with the tubing we are discussing in 'standard' builds.
I know, I was just countering what the other guy above was saying (as 3/8'' isn't going to be anywhere near a 'restriction' in 'standard' builds)
