I don't know about all Focii, but it would seem some are built like that just missing various components. I assume its more cost effective to simply build all the cars the same, and then fit the essential looms and switches only to certain models.
It's rather annoying...I can actually see the heating element in my screen (especially in direct sunlight), but I cant use it. I did read that if the car has the correct loom, it may simply be a case of fitting a new switch and fuse and off you go....I cant see it being that simple though.
