Does this support 1TB drives?
Have a look at the Wiki as it has a list of tested drives, there are some 1TB ones on the list.
There's a link to the manual and info on the latest firmware update that adds ssh-server and streamripper.
I was one of the lucky ones who managed to get one from the first batch, arrived this afternoon, so thought I would post quickly with my first impressions.
The cady is smaller than I expected, barely any wider than a HDD and not much higher than 2 drives stacked. In typical Icybox fashion, its a very sturdy attrasctive piece of kit.
Setup is a breeze, installed 2 hard drives, turned it on, opened the config from a browser and had it configuring RAID 1 within 5 minutes.
Plugged in my printer and configured windows to use it with no problems.
Haven't played with the user and groups options as I have no need to control access, so as it is, everyone can access the data on it.
Its pretty quiet, the fan is temperature controlled, I get a little bit of vibration through the feet, but putting a few bits of cardboard underneath has sorted that.
Haven't tried any of the other server functions yet, but all in all, I am very pleased.
Yes, also known as JBOD (just a bunch of disks)If you put in two discs and dont want any form of raid will they show up as two discs?
Yes, as long as you format as FAT32Then if you took one out would it be readable by a normal pc?
Lastly if you only put one disc in and one later on with it show up as two and would there be any issueS?
Yes, as long as you don't want to RAID them - all data will be wiped when creating the RAID array.
You may find this link helpfull (you can download the manual)
Cheers anyhow!
If you want, you can join us in the community at the English Board
Being my first foray into NAS/Raid can somebody just put my mind at rest over the overhead on the discs.
I have 2x WD 500GB AAKS in span (nraid) and they are formatted to EXT3. The NAS4220 reports the total volume to be 915GB and XP confirms this but XP is showing only 869GB free space
Is it something to do with how XP deals with the EXT3 file system ?
Seems like a lot to lose, can anyone explain please![]()
