[TW]Fox;10659609 said:I'm using Edge 0w30, have I picked the right oil?
[TW]Fox;10659783 said:Nowhere, there just seems confusion over whether 10w40 or 0w30 is best thats all![]()
Tempting. The Vette's supposed to be lubed with Mobil 1 5w/30 synthetic (when new, so a good 12 years ago now), so I guess this Edge would probably do just as a sufficient a job, if not better?
If it's effectively half the price of doing it myself, I'll just drive it into one of these centres. How odd though, having someone do the work for me!
I suspect I'll have to supply the filter though
'tis only an iron block/alloy head V8 so probably fairly flexible with regards to oil but it does run hot (by design), so needs something that doesn't mind sustained high temperature operation![]()
It wouldn't suprise me if they could to be fair, I just always assume they'll never have the bits!![]()
Do they use genuine part oil filters?
[TW]Fox;10660169 said:Mobil 1 10w40 Fully synthetic.
0w30 will provide better fuel economy and I know how much you like that![]()
When the oil's less than half the price to buy though, I know what I'd rather pick
Used Mobil 1 0W-40 in my car at the last two services, and it's been fine![]()
About £45 for 8l from Costco. Gives you 1.5l left over to top-up with between services which is quite handy. BMW want over £100 for 6.5l of Castrol and obviously you get none to top up with either.
