Have you considered the Pizza overclocking that Easys been doing?
ps3ud0![]()
Lagging? those scores are pretty uber?Looking around, Im wondering if its PCIe 2.0? Seems to be P35 boards lagging next to Easy's x38.
The X38 platform scores an extra 26 points in the SM3 tests? Is that a lot extra?Easy's at 800/1950/2200
17443, SM2 7267, SM3 6935, CPU 6347
Mine 850/2125/2200
17478 SM2 7398, SM3 6909, CPU 6193
Another P35 850/2125/2200
17922 SM2 7428, SM3 6883, CPU 7245
Maybe leaping to conclusions re the PCI-E 2.0 is a bit premature? I'm sure there are plenty of other variables. . .
Have you tried running the test at the same exact clock? Maybe yours is too high and some weird throttling is occurring somewhere?
Spent way too much time studying results over the years, I'm fairly good at estimating the results. I didnt say it was a lot in the grand scheme of things, a few hundred points. But to my mind the x38 score is ahead of P35 at the same clocks. Take a look through the HWBOT results, thats a really nice SM3 Easy has, better than a QX9650@4350, ram at 775MHz and the core is 850/2125Mhz. A few points either way sure, but there looks like more to it than variation. At 800/2000Mhz I would expect to see SM3 around 6750. Personally I just like to know why is all, one possible differance between the P35 to X38 that might apply is the revised PCIe bus.
Mine 800/2000/2200 17055 SM2 7138, SM3 6749, CPU 6207
. Takes a lot of time off the "tip toe" overclocking style.Well it's a £150 chipset so you would really hope there was something better about it, however are we talking about 1fps or 2 fps difference here?to my mind the x38 score is ahead of P35 at the same clocks
I have to see pictures or a graph to really get the gist of what you are saying.thats a really nice SM3 Easy has, better than a QX9650@4350, ram at 775MHz and the core is 850/2125Mhz.
That's good, I suppose Sir Isaac Newton felt the same way when he saw apples falling to the ground.Personally I just like to know why is all
What points is that Devious? Total 3Dmark06 points or?i get 300 less points with higher clocks
What version of Rivatuner are you guys using? I have 2.06 and its says its not supported and wont let me over clock it.
Thanks easy, got a problem though.
I found it, opened it with notepad and added the line but it wont let me save it, says
Cannot create the C:\Program Files\RivaTuner v2.06\RivaTuner.cfg file.
Make sure the path and file name are correct. Huh??
Ah thanks mate, working now.
Now to overclock, any suggestions for a 1st attempt? stock air cooling
Will the overclock only still work while rivatuner is running? If so ill make it go to system tray.
Just going over the scores with Easy, something is boosting his SM3 scores over where it should be compared to all the other results I've seen. Looking around, Im wondering if its PCIe 2.0? Seems to be P35 boards lagging next to Easy's x38.
