The program is no doubt incomplete regarding correct fillrates etc.
thats ok then im running 0.1.3 ah well
yeah ure right everest is reporting
Texel Fillrate 15552
Anyone able to give me some help, installed latest 169.21 drivers and now I dont see any options for forceware in rivatuner so cant overclock, am I missing something?
Anyone stuck one under water yet and using what block?
Got an Ek block sat here but I'm not sure if its worth the £55, would I see that much of a difference? Otherwise it will get sent back!
Is that right? have people been testing the 8800GTS 512MB long enough to have figured this out?Thing is with these G92 GTS/GT they are not really limited by heat (clocking wise)
What about the 8800GTX? did that overclock better with more cooling?more testing may be required
im using ntune atm which seems to be working well with the 21's
Anyone noticed that in project manager it says Generic VGA![]()
Thing is with these G92 GTS/GT they are not really limited by heat (clocking wise) therefore the block is only really worth it if you want to quieten the system down by putting the GTS on the loop
The thing is you have no experience with this card.
Does he have any experience with a GTX ??![]()
agent provocateurDoes he have any experience with a GTX ??![]()
