Just wondered how many MM is sticking out the top of the nut so I know I have the right level of pressureResults in from overclock3d ...
put in a quad nozzle and/or bow the block and the fuzion comes very close or most likely even beats the EK.
No real need to get rid of my MP-05 Pro limited edtion yet then. When a block comes out that shows a massive difference (not very likely it would seem) then i shall swap it out.
It may also help to lap your cpu if its concaved ...
How tight do you have the block screwed on?
How much of the screw is sticking out of the top nut?
d-tek fuzion + nozzle tied with a Apogee GTX?
controversial![]()
DON'T LAP ANYTHING WITH THE EK!!!!!
It's intentionally bowed (big-time) to press down on the cores.
Thanks WJA, when I get this backplate on Monday I'll make sure the springs are right down.
So you probably have about 10-15mm of the supplied screw sticking out ?
Damn, my CPU is already lapped.
Does this mean that the EK will be no good for me? Would I have been better off with the Fuzion?
It doesn't matter if you've lapped your processor or not, the bow isn't really there to counter act miss-shaped IHS'
Edit: WJA96, which orientation did you mount the EK?
