which is the correct temp
Because that is what they do. Intel TAT reads it directly off the chip, most motherboards infer the CPU temp from a sensor in the socket.
Jokester
TAT is reading the core temp, where as the motherboard is reading the temp from the socket (this may be wrong!)
Edit: seems it wasn't and I was 30 seconds to slow :)
Thanks very much when i run intel tat with workload 100% on both cores max temp is 59c does this sound ok what are the max safe temps a for a e6600.
The processor's thermal protection will kick in before it damages the CPU, can't remember off hand for the E6600, but it'll be something like 85C that it starts to throttle.
Jokester
