I'm guessing you're quite sensitive to CRT monitors, too? Also I bet you can see the "rainbow effect" on DLP projectors?
[TW]Fox;10703663 said:Mine don't flicker![]()
I notice they flicker as you look away from them, somthing to do with your eyes/brain?
Quite distracting tbh.
Yes, I can see both.If you have sensitive eyes, then you can see the flicker - most LEDs (especially when low-power usage, such as cat's eyes) are driven by PWM - Pulse Width Modulation - it "pulses" power to and from the LED, and the faster it's done, the brighter it will go. With most LEDs, you can drive them at ~50% modulation, and they'll appear to most people as static, and on fully.
