Ahhh, I see what you mean. I meant, google the first entry in the list and then work your way down. You may be experiencing a cascade of errors so if you fix one, then the rest will fall into line. Maybe.
EDIT: I have looked around and found this thread which may contain the answer to your problems:-
http://groups.google.com/group/micr...ad/74878d9981e012ec/d637d3d5e2d03539?lnk=raot
It sounds similar to what you are experiencing but may not be the solution for you. Your error code is mentioned there at some point but I don't know if the guy fixed it.
Have you tried using a program like CCleaner to scan your registry?
