Not at all, Linux has its uses - and many uses at that - but for the home and general office, Linux is not the answer (nor any Unix sister i.e. Mac OS).
Seems to work for me.
 Thats why it took me a lot of time to get working.Care to add how to install M-Audio Revolution 5.1 drivers, and to get SPDIF port to work (PCM/DD/DTS?)
Also how to get MS 5 button mouse to work (forward/back etc)
I'm looking forward to hearing your arguments as to why I shouldn't be using Linux either at home or in the officeNot at all, Linux has its uses - and many uses at that - but for the home and general office, Linux is not the answer (nor any Unix sister i.e. Mac OS).
Only reason Linux isn't on my main box 24/7 is the lack of a decent media management application. There's nothing yet that'll allow me to build a totally custom library structure encompassing data, video (With thumbs), audio and other bits and peices. The laptop runs Linux exclusively, as does the server, and both have been like that for well over 5 years.
I'm looking forward to hearing your arguments as to why I shouldn't be using Linux either at home or in the office![]()
Likewise
I use Ubuntu as a home desktop and rarely if ever touch XP now. (Admittedly I'm not a gamer, which tbh is the only reason I can think of for keeping windows)
Windows especially annoys me in this regard, as it simply doesn't allow acccess to any of the more useful bits and peices, and if things break majorly things usually end in a reinstall. Linux on the other hand, all I need is my standard rescue disk, mount the partitions and fix things up.
Over the years I have had a few attempts at getting a useable linux OS.
Firstly it was hampered by no support for my Netgear wireless card. I wasted about 14hrs solid tinkering with unfamiliar stuff like ndiswrapper trying to get it to work and in the end I gave up.
This time round I tried ubuntu gutsy gibbon. I was very pleased and impressed at first how much worked out of the box on my new dell vostro 1500.
However the stumbling block has come around. No sound.
After googling and searching I've found a couple of "fixes" but these involve line after line of unfamiliar code to enter in a terminal window. Which produced many error reports anyway so didn't work.
I find it hard to believe it can really be this difficult just to get your system to an acceptable level of functionality.
I appreciate that Linux is the "nerds choice" but I'm stuck in a Catch 22 where I'm having to learn command line stuff just to get the thing to work. I'm pretty handy with windows and can't believe anyone can honestly criticise windows when linux is this bad just to get started.
Or am I missing something. Please help me get a working OS just so I have an option of escaping from Bill Gates' monopoly!!!!
I'm not sure what experience you have with Microsoft products but they are more flexible than you think. Yes Microsoft products are probably not as breakable and fixable as Linux (my Linux experience isn't as strong as my MS). Microsoft have great support with a centralised and reliable support site which is always good.
Looking at forums on ones experience can be scary with Linux if you don't know what you’re doing. Which brings us back to the break it and fix it issue.
I can't wait for the next five years for Linux. Ubuntu is certainly leading the way and brinking Linux to the home. Apple are also working hard and are chipping away a little at the MS home desktop.
There are rescue and repair cd's for Microsoft products, they are standard on windows 2003 and XP. I've successfully restored broken systems with them. I’ve also restored broken registry settings and parts of Active Directory to get a system back online.Plenty of experience with MS products, thanks
Delete the wrong set of things, and you'll end up with a re-install on your hands. There's no real way to fix Windows if the whole system is broken to the point of unbootability- With Linux, its possible to load a rescue system from a CD etc. and completely rebuild the system from the ground up.
Tell me for instance how I can build a completely custom menu system without resorting to third party apps, or one incredibly simple problem- There's no way to mount network drives in a folder, they have to have a drive letter.
Another example- Windows had no concept of properly restricted user accounts until Vista (Admittedly not 100% MS's fault, too many people designing the simplest of apps to need admin priveledges), and even then they horribly messed things up with the abomination that is UAC.
Windows simply doesn't cut the mustard where I'm concerned.
Just to get my desktop to what I consider to be a usable state, I need 4 third party apps. (ObjectBar- Menu bar replacement, ObjectDock- Runs three different docks across my two monitors, Ultramon- Makes multiple monitors work halfway decently, Firefox & 13 extensions- Self explanatory!)
-Leezer-
 I’m looking forward to seeing Linux (and apple) develop over the next few years.A working distro at last.....I'm now ready to learn.
 The rest is learning...Suggesting new users use Gentoo is pure craziness and bad for the wider acceptance of linux. As Bes says, it's only likely to scare new users off linux completely.
Install ubuntu. Once you feel familiar with it, if you want to experiment with other distro's then go ahead but expect days of frustration when 'nothing just works' (tm). Honestly, ubuntu is the best thing to ever happen to linux. It's easy to use, has a fair amount of polish, wide compatability. New users do not want to spend days on the command line trying to get their first linux distro to work.
Computer geeks always want to be counter culture and that's fine, but let's not inadvertantly damage linux acceptance through your own preferences.
