Going to be doing some benches of various titles in single v crossfire mode, using game bench where possible and FRAPS when not.
CRYSIS
1920x1200 no AA/AF - Vista x64 - DX9 - Q6600 @ 3.8ghz - 850/1200 GPU - 7.12 cat
as you can see below the scaling is very good with 7.12 in crysis even without the coming 'multi gpu enhanced' patch from the devs.
Catalyst optimisations set to maximum quality
Crysis settings - mix of medium/high
Single HD3870 XT
24/12/2007 16:52:35 - Vista 64
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1900x1200, AA=No AA, Vsync=Disabled, 64 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: Custom
Custom Quality Values:
VolumetricEffects=Medium
Texture=High
ObjectDetail=High
Sound=Medium
Shadows=Medium
Water=High
Physics=High
Particles=Medium
Shading=High
PostProcessing=Medium
GameEffects=Medium
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 72.27s, Average FPS: 27.67
Min FPS: 23.13 at frame 1299, Max FPS: 35.14 at frame 987
Average Tri/Sec: -28736632, Tri/Frame: -1038380
Recorded/Played Tris ratio: -0.88
!TimeDemo Run 1 Finished.
Play Time: 65.48s, Average FPS: 30.55
Min FPS: 23.13 at frame 1299, Max FPS: 35.94 at frame 987
Average Tri/Sec: -31281100, Tri/Frame: -1024081
Recorded/Played Tris ratio: -0.90
!TimeDemo Run 2 Finished.
Play Time: 65.40s, Average FPS: 30.58
Average Tri/Sec: -31329240, Tri/Frame: -1024450
Recorded/Played Tris ratio: -0.89
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1900x1200 AA=No AA, 64 bit test, Quality: Custom ~~ Overall Average FPS: 30.565
Crossfire HD3870 XT
24/12/2007 16:28:54 - Vista 64
Texture=High
ObjectDetail=High
Sound=Medium
Shadows=Medium
Water=High
Physics=High
Particles=Medium
Shading=High
GameEffects=Medium
Play Time: 43.91s, Average FPS: 45.55
Min FPS: 34.47 at frame 1944, Max FPS: 64.09 at frame 898
Average Tri/Sec: -45062252, Tri/Frame: -989323
Recorded/Played Tris ratio: -0.93
Play Time: 36.98s, Average FPS: 54.08
Min FPS: 34.47 at frame 1944, Max FPS: 64.58 at frame 946
Average Tri/Sec: -52660052, Tri/Frame: -973680
Recorded/Played Tris ratio: -0.94
Play Time: 36.89s, Average FPS: 54.21
Min FPS: 34.47 at frame 1944, Max FPS: 65.20 at frame 901
Average Tri/Sec: -52821840, Tri/Frame: -974306
Completed All Tests
Run #1- DX9 1900x1200 AA=No AA, 64 bit test, Quality: Custom ~~ Overall Average FPS: 54.145
Crysis settings - High
Single HD3870 XT
24/12/2007 17:05:01 - Vista 64
Global Game Quality: High
Play Time: 98.25s, Average FPS: 20.36
Min FPS: 9.80 at frame 97, Max FPS: 24.30 at frame 1766
Average Tri/Sec: -19108060, Tri/Frame: -938721
Recorded/Played Tris ratio: -0.98
Play Time: 90.41s, Average FPS: 22.12
Min FPS: 9.80 at frame 97, Max FPS: 25.03 at frame 996
Average Tri/Sec: -20515902, Tri/Frame: -927398
Recorded/Played Tris ratio: -0.99
Play Time: 90.90s, Average FPS: 22.00
Min FPS: 9.80 at frame 97, Max FPS: 25.27 at frame 1001
Average Tri/Sec: -20398410, Tri/Frame: -927123
Completed All Tests
Run #1- DX9 1900x1200 AA=No AA, 64 bit test, Quality: High ~~ Overall Average FPS: 22.06
Crossfire HD3870 XT
24/12/2007 16:37:21 - Vista 64
Play Time: 59.15s, Average FPS: 33.81
Min FPS: 27.68 at frame 158, Max FPS: 43.95 at frame 880
Average Tri/Sec: -24553254, Tri/Frame: -726183
Recorded/Played Tris ratio: -1.26
Play Time: 51.91s, Average FPS: 38.53
Min FPS: 27.68 at frame 158, Max FPS: 44.76 at frame 834
Average Tri/Sec: -27834230, Tri/Frame: -722435
Recorded/Played Tris ratio: -1.27
Play Time: 51.78s, Average FPS: 38.62
Min FPS: 27.68 at frame 158, Max FPS: 46.34 at frame 1013
Average Tri/Sec: -27921360, Tri/Frame: -722883
Completed All Tests
Run #1- DX9 1900x1200 AA=No AA, 64 bit test, Quality: High ~~ Overall Average FPS: 38.575
CRYSIS
Single HD3870 XT
Texture=High
ObjectDetail=High
Sound=Medium
Shadows=Medium
Water=High
Physics=High
Particles=Medium
Shading=High
GameEffects=Medium
Completed All Tests
Crossfire HD3870 XT
Texture=High
ObjectDetail=High
Sound=Medium
Shadows=Medium
Water=High
Physics=High
Particles=Medium
Shading=High
GameEffects=Medium
Completed All Tests
Single HD3870 XT
Completed All Tests
Crossfire HD3870 XT
Completed All Tests
