- 23 May 2006
- Blythe
as title looking as cheap as possible to play Crysis & COD4
thanks
thanks
Do you have a rough idea of a budget you're aiming for, and any preference when it comes to things like heat and noise? We should be able to pin something down nicely that suits your needs.as title looking as cheap as possible to play Crysis & COD4
I can't see him having much fun playing Crysis on those and he might have something better already.NVIDIA GeForce 6800 GT, ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or better
The 8800GT and 8800GTX are the popular choices at the moment. From my experience the 8800GT handles Crysis on all high in 1680x1050 and the 8800GTX handles it the same, but the extra memory gives you a bit of legroom to use a decent amount of antialiasing.I've got a 6800GT already, PCI-E, overclocked it today to see if it will make an ounce of difference I doubt it though. I've got an SLI board but I'm not bothered about that because I'm not spending that much to get 2 cards. heat and noise to a minimum please : not bothered about budget just give me a range please![]()
I think it'd be much better if you specify some rough sort of budget, then you can decide if it's ideal for you to try stretching or even going lower. If you're after something a little lower priced than the 8800 Series then the X1950Pro 512MB is a great buy at under £100, and it'd be a huge improvement from a 6800GT.as in not bothered about budget I meant as cheap as possible but not going to specify incase there is nothing I can get in that price range.
so whats the best budget atm? ati or nvid ?
The 8600GTS 512MB is about £100 and should suit your needs, but it will struggle a lot in some games.I'm after something that will do DX 10, for around 100 lower if poss
I don't really know anything about ATI's current mid-range I'm afraid.ah right, what cards in the ATI range are up to it? I wasn't impressed at first glance
I was aware of that but pretty much no £100 or under card will play nice with Crysis, period and he specifically stated that he wanted DirectX 10 support which takes the X1950Pro out of the picture.the 8600gts is not one of them.
Aye 512MB is important for a lot of games now, including Crysis and Call Of Duty 4.I think 512mb memory would be preferable for Crysis.
It also has a crippled 128bit memory bus as well though so I'd advise looking at mid-range ATI cards.
I can't really comment on the 3850s but if they're good then it sounds like a plan. Seriously plump for the 512MB model though, you'll regret playing Crysis on a 256MB graphics card.I think a 3850 256mb would be a better buy or £20 more and get a 3850 512mb depending on his resolution. More performance than the 8600gt and in a similar price bracked as the 512mb version.
btw nothing is really going to play crysis smoothly at decent fps and quality/rez for under £200 really. even the best of the cards are having trouble. Next gen may yeald better results.
Agreed.
