My pc wont let me overclock :(
10 Nov 2007
I've got a problem overclocking, my pc wont let me do it :s
When i go into the bios and attempt to change the fsb or voltage or most cpu related options it simply wont let me i cant get it open them so i could change them by even 1hz
i know its nothing to do with the system cause ive probably got one of the most popular setups
Q6600 @ 2.4ghz w/ TRU 120 Extreme Scythe Flex 1600 rpm fan
ASUS P5E X38 Motherboard
Patriot Extreme 1066 2gb
Ati HD 3870 512mb
OCZ Modxstream 720 Watt
Antec 900
Anyone have any ideas
Oh and i have Asus Suite Installed i've thought that my be the problem but want to be sure as i cant find the disk to reinstall it lol
cheers
Remove the power lead and pop the motherboard battery for 5 minutes.
You'll probably need to re-set the clock when you get back into the BIOS.
please read your motherboard manual in detail before fudging around with it! it will help, it WILL tell you how to clear the CMOS and it WILL tell you how to overclock!
