Consigliere
- 12 Jun 2004
- SW17
I've just sprayed myself.
Odourless antipersperant, plus your after shave of chocie (but never joop), is the key to sucess.
I beg your pardon! I meant anything to avoid the combination of odours... aftershave, Eau de Parfum/ Toilet etc (except joopCorrect, apart from the 'aftershave' bit. Replace aftershave with a suitable Eau de Parfum fragrance.
I personally use a neutral or very light smelling anti perspirant in moderation and apply a fragrance just before I leave. I have a collection of frangrances by Creed and use whichever is best suited to the event.
There is no excuse for joop.
Why would you only use deodorant.../so confused.
I use both, Lynx deo and Joop aftershaves.
Very sexual.
Deo is for sweat prevention
I think lynx tends to get more disrespect than it deserves. Not that I wear it mind. Its not great, not bad. Wouldn't wear it to go out for an occation!The two things all the girls I know have told me specifically to never wear![]()
Usually Ted Baker deodorant and Issey Miyake eau de toilette.
Then ruin it all by downing 15 JD and cokes and smoking 20 fags...
