hi ive just bought the mrs a new latop its TOSHIBA EQUIUM A200-1VO £399
The battery is only lasting about 1hour -120 mins i have set the power settings to balanced and the screen brightness is 45% when on battery, disabled the slidebar and disabled windows aero. all other settings as far as i know are set to save power as i spent a good half hour on the power options.
i know vista will use more battery life than my old laptop which has xp but i was expecting a good 2hours on a brand new battery im i expecting too much for a £399 laptop???.
i have also let the battery run down to 2% which is the lowest i can run it down before the sleep hibernate shutdown settings kick in and then left it to charge overnight but still not happy which the battery life time. do i have to calibrate the battery a few times to get better battery life or is the 1hour -120mins using vista correct for a cheaper laptop. please can someone help me on this.
