Does anyone still play everquest 2
Stop splitting hairs. They mutilated nothing. I have no clue what you are going on about.
Splitting hairs? Maybe, class abilities do indeed define the class which again comes down to the same point of class abilities being mutilated (maybe I really should use 'adjusted') specifically to balance a PvP server, thus a PvP Ranger is not what SOE intended a Ranger to be, the same can be said for all classes.
If you are getting ganked over and over then, to put it simply, you are doing something wrong. Don't walk right through busy areas, stop going back to where you got ganked, or travel with friends and kill them back. Not exactly rocket science.
How about just don't play PvP? Works for me and many others.
As it is incredibly easy to avoid being ganked once let alone repeatedly I can only assume either 1) you have never actually played on a PvP server, 2) you have but had no clue what you were doing or 3) You are scared of dying for some reason, even though you don't lose a thing in doing so. :)
1) Yes I have, I even beta tested EQ2 PvP which was to be honest great fun for a while and probably one of the most chaotic gameplay experiences I've ever had outside of the Battlefield games, but it got old very quickly for reasons I've already stated.
2) I've played plenty enough PvP games to have a reasonable idea of what I'm doing thankyou.
3) Again I'll re-iterate the fact that fear has nothing to do with it, sadly somebody who cannot see the attraction of a PvE server whatsoever is unlikely to ever understand this but I'll try to explain it.
I have no wish to have my game time and play style in EQ2 dictated to me by the threat of other players, I have plenty of other games that are far better suited to PvP and far more enjoyable than EQ2 PvP is ever likely to be for me.
I stopped playing WoW properly (I hope for good, WotLK will be interesting for 2-3 months then will blend back in to the rest of the boredom :p) in August-ish, and hadn't played EQ2 since January 2005.
The similarities between the two games now though are a lot more common, as it helps newcomers from other games get used to it pretty quickly, UI still feels a little awkward still, not really sure how customisable the interface is for EQ2 since release. Also found my old chars still on Splitpaw (16 Shaman, 16 Brawler, 8 Mage, 8 Scout) so that's the inactivity policy gone out the window :D
The amount of classes is actually a little overwhelming, better than just 9 though, although I like variety; but I get too carried away with alts sometimes as I love trying out every class.
Started a Wood Elf Conjourer today & have got to lvl 10 but not really enjoying this character or the starting area
I actually found Kelethin a lot easier to level in than Qeynos, which has you running all over the place by your mid teens. Once you get over the desire to throttle all the little fairies, that is :)
Don't neglect your character's racial special ability when starting a character either, the safe fall that high and dark elves get is a huge bonus, as is the limited stealth that wood elves get.
I am a bit stuck on a couple of quests, the main one being Mysterious Machine.
I have found the machine and when I examine it it asks me to attach the arcanic beacon which I have in my inv. but how???? if I click on the item then on the machine the only option I have is to destroy the item which I don't want to do.
I have looked this quest up on wikia and it says:
  1. Inspect the machine in the center of the lake. (670, 500)
  2. Slay a gnoll machinist who spawns and attacks you (level 8).
  3. Inspect the machine again.
  4. Return to Lieutenant Dawson for your reward.
The gnoll machinist never spawns for me?
I had a similar problem with an earlier quest where I had to place something on a memorial stone I couldn't do that either only option again was to destroy item, what am I doing wrong??????????????????
Double click on the machine should do it, if not it can sometimes be worth logging out and back in again.
Ok, just been and tried this myself.
Find the machine, inspect it by either right click or double left click, attach beacon timer appears but before it completes the Gnoll machinist appears, kill him and then attach the beacon again. Job done.
Now if that doesn't work for you the best thing to do is to delete the quest and go talk to the quest giver again and re-aquire the quest.
Any class on a PvP server is EXACTLY THE SAME as it is on a PvE server. Each spell has a different set of attributes in PvP combat ONLY - usually just less damage - which is to stop basic and low damage spells from doing things like 1 shotting players, who have considerably less HP than any mob, as that would make it totally pointless. The ONLY time this is ever an issue is if you get attacked in a public place while you are currently attacking a mob, but that doesn't happen at all often enough for it to be an issue and most things in the game die in less than a minute anyway.
A PvP Ranger is still exactly as they intended it to be and more as it can now PvP as well! I don't like rangers though *stokes my Wizard hat*
Totally boring in my opinion. I don't see why anyone would not want to PvP. The game is not worth playing without it for any significant length of time. The entire point of playing an MMO is to play with others. What's the point in playing with others if you can't kill them too?!
They have improved the game a lot since PvP came out. A lot of the annoying issues have been fixed. But I don't know why you found it chaotic. See my next point below.
Without sounding rude, it's clear you don't, otherwise you would know how to avoid getting ganked and that it is not chaotic at all. A good PvP battle is as organised and precise as a high end raid. Obviously you get people who don't know exactly what they are doing attacking you, but that just makes it easier not chaotic. Raid vs raid PvP can get a little messy, but if you are in a good guild who has members who know their class and can control themselves then you should have no problems.
See now I just don't understand that at all. What other game of its type is more suited to PvP than EQ2 is? The way it is implemented is better than another other MMO out today, other than EVE. Yes, it has a few annoying problems, but they are present in most games so it doesn't bother me.
In what way is your gameplay "dictated to you" by other players? I could go a day without engaging in any PvP if I wanted to, without any major adjustment in what I do or how I go about it. Most important/fun/useful parts of the game are instances anyway.
What do you do with your time? You might raid, but that is only a few hours gone, what about the rest? Zones and instances? Surly you get bored of them after you have done them all 20 times? Then what else, maybe mine some nice rocks and craft something? EQ2 has the most boring crafting system in existence! PvP makes the game come alive and means there's always something fun and dynamic to do.
I'm not having a go at you or anything, I just don't get it :):p
