Caporegime
- 8 Jan 2004
- Rutland
Not looking bad at all for the price.
Not bad for the price. My first concern is the .35 overvolt option on the ram giving a max 2.15 (correct?) That may limit some people. Whats the max vcore?
I hope you get more out of it WJA, is the q6600 a good clocker on a previous board - comparisons?
WJA, do ICH9 support AHCI ?? please let me know.
I'll reflect for you.
From what I read elsewhere, ICH9 is IDE only, whilst ICH9R is capable of RAID/AHCI.
I think I need much more chipset voltage, but if I use the 1.65V setting, the Northbridge heatsink heats up like crazy, so I think that's going to be the limiting factor as I'm not prepared to mess about with the heatsinks at this time - especially until the resolve the issue with SATA II.
above: quad settings for 400*9 taken with camera...my 24/7 settings...
my old v1.0 bios doesn't show vcore correctly, please ignore it. PCI-E @ 110 is just my own preference...someone said 118 is the best.... :O
Is there any reason why you haven't upgraded to the shipping BIOS - v1.2?
I've tried messing about with the PCIe clock as well, but it doesn't seem to make any real difference.
One thing I have noticed is that I seem to get very inconsistent overclock speeds every time I boot. It's almost like the CPU clock generator isn't consistent.
I have tried to manually key in the default timings but the menu options don't allow numbers high enough - the tRAS Precharge Delay only goes as high as 15 and my Crucial Ballistix needs 18 to stable at over 1000MHz.
Again - this seems to be a BIOS issue as the board correctly detects the SPD timing of 5-5-5-18 and sets it, but I can't set it manually.
This is also the case for some other numbers eg. Refresh Cycle Time only goes to 31 but my RAM isn'ts table at that.
The other thing I have noticed is that since I have started adjusting the RAM the machine no longer auto-recovers from a failed boot - I now have to use the BIOS reset jumper.
I still haven't use the jumper till now.I still haven't use the jumper till now.
