yes it has mistakes in it, but no mistakes in it are critical, eve the virgin mary one if that is a mistake its not even critical to the christian message.
The mistakes are critical if you believe in an omniscient God, which, as a Christian, I assume you do. An omniscient God can't make mistakes so you'll have to find an explanation for them.
The Christian belief is based on the fact that the bible is the word of God. If some parts can be ignored (such as the contradictions) which parts do you follow and which do you not? Is homosexuality a sin or not? It's in the bible but maybe that's a mistake as well and not necessary for the Christian message?
The most likely scenario is that the mistakes are present because man wrote the bible without any help from God.
yantorsen said:yes there is, if you think personal acounts can be evident? (inc. ones not in the bible or even by christians, but by Romans.) if you don't then there isn't.
Personal accounts can be evidence. Although it's unlikely in this circumstance that it would sway my mind. I'm curious though, please tell me where the personal account is documented that comments on Jesus' supernatural ability.
