Caporegime
- 8 Jul 2003
- In a house
Doesn't sound normal to me, my GT's on auto fan speed (29% or whatever it is), and underload goes to about 85 and ive never had any probs, runs fine.
I think I'm going to RMA. I think its quite perculiar when my friend has exactly the same card as me (POV) and his plays all games without altering any fan speeds yet mine is unstable. I'm not happy with it. So I'm looking for a cheap PCI-E card to replace it during the RMA period.
_________________________
I can replace this card with either another Point of View, Leadtek.
Or I can for another £15-20 afford to get a 512MB GTS.
What should I do folks?
Which version of the Leadtek has the better cooler? Or does it come as standard now?
.The card is created for the temps what is produce , and have to handle with it , When you have problems, please tell me what problems
You are able to increase the Fanspeed – with Rivatuner http://downloads.guru3d.com/downloadget.php?id=163&file=5&evp=2d213e528fb556c354432a3976bff55a .
With kind regards
Point of View / technical Department
English speak is ours not good. Fans with Rivatuner adjust you must.
Starting to sound like a chinese yoda if you ask me!
RMA, get the Leadtek one like mine![]()
Well my RMA reported a faulty card and therefore they have replaced it with a Leadtek which is on its way!!![]()
