Hi all,
Need your advice on some av equipment i need to get for my brother. he basically has £1000 spend on a new amp and 5.1 speaker set.
He has to spend <£500 on each item.
Ive narrowed down the amps to the Onkyo 605 or Sony STR DG910. I like the Sony because it has an extra HDMI compared to the Onkyo. It also costs £100 less than the Onkyo. Out of the two which would you suggest and the reasons why.
He also needs a 5.1 setup too. Whats good out there for <£500. Any suggestions would be welcome....the £500 budget will also include speaker wire and all other cables etc needed to get up and running. I quite like the look of the Mordaunt Short Avant Premiere Plus set.
If possible he would like to spend the least he can but has set a max budget on £500 for each item.
Your suggestions would be very welcome.
Cheers
Cheers
