- 7 Feb 2004
I have overclocked my core and mem but dont know how to overclock the shaders?
I am using nivatuner 2.06
Thanks
Thanks
You can't do it separately in rivatuner but the shaders overclock with the core.
If you use gpuz it will show you your current core, shader and memory clocks.
You can overclock shaders separately
How do you get to that with nivatuner?
I run a 3d mark 06 test and got 10991
Whats that like?
640 core and 1000 mem - 70 degrees using atitool
If your on xp you must go to power user system rivatuner and make nvidiausagebehaviour set to 1 that unlocks the shader slider
Think the Gainward app can, not sure tho.
Can someone confirm?
Go to the power user tab, in there should be loads of drop down menu's, go to system and within system should be nvidiausagebehaviour. Click to the right and set at 1. Hope that helps!
