- 12 Jun 2005
Hi all,
Ive just got my hands on a Asus 8800 GTS 320 meg the g80 one. Ive installed it everything works fine including 3dmark 06 apart from Crysis.
I started playing with all setting on high at 1280x1024. During the game ive noticed some stuttering. Periods of 5 secs where it hangs then upto 3 mins of play before it happens again.
I proceeded to turn everything to medium and there where no problems.
I then moved and run the Crysis bench mark at high settings. The hang thing happend again but much more frequently during the bechmark. It then proceeded to crash and i had to end the program.
Is this a common problem on high settings or is there something else i can try?
System specs are:
e6300 @ 3.2
2gig G.Skill 6400 4-4-4-12
DS3 Rev 1
Asus 8800GTS G80 @ Stock
Vista 32
Many thanks
System specs are:
e6300 @ 3.2
DS3 Rev 1
Vista 32
Many thanks
