News in, Barcelona B3s are just fine. B3 = end of 65nm for AMD.
10 Oct 2007
in the arse of england.
there are a bunch of rumours floating about AMD's B3 stepping parts, saying they are have the same bug as the B2, IE the new step did not fix things. This is categorically not the case, it was, is, and never will be true.
When the rumours started to fly, I called AMD and talked to Pat Moorehead who answered all of my questions. The B3s are not bugged, period. The fix was tested on B2 silicon and verified (Don't ask, the elves who work at the Fraternal Order of Silicon Repair Mythical Creatures Local 17 get antsy if you reveal their secrets).
Basically there is no B4, there won't be a B4, and the next stepping is Cx. The Cx parts are the 45nm Shanghai cores, so the B3 will be the end of the line for 65nm. B3s are going to be sampling in the not so distant future, production in the end of Q1, and retail availability in Q2. That part is a slip.
In summary, B3 is fine. It is a little later than people expect, but what can you do? The fixed chips are on the way, sit tight, it is only a few weeks before this soap opera ends
http://www.theinquirer.net/gb/inquirer/news/2008/01/11/barcelona-b3s-fine
hopefully this is all true and things will start to look a little brighter for AMD soon. :)
6x86 for the win... in Integer performance per clock. Damn its weak clock scaling and floating point unit! Damn VIA for buying and not doing anything useful with a potentially strong architecture and turning it into C3!
Even more interesting is the comment at the bottom of the article about the bugs in Intel CPU's - haven't seen that plastered all over the press..
What about the new bugs found on QX9600 and Harpertown?
Accordings to the german http://www.heise.de/ct/08/02/018/ intel has updated it's CPU bug list twice during December 07. It says that AMDs TLB bug almost sounds harmless compared to the list of new bugs found on intels CPUs. Funnily enough there even is one affecting the TLB :-)
Ooooh Intel is hitting problems :eek:. AMD will be loving this :p.
Guarantee nobody harks on about these bugs and how appaling and disasterous they are. The way people have been going on about the Phenom TLB bug you'd think it could cause a small nuclear explosion.
I'll be interested in the B3 stepping CPUs once they hit the under £100 mark. If they can release a chip that reliably gets to 3Ghz then it will be a good buy.
thats because a lot of the tech press love controversy and drama. intel has its own bugs but they are kept very VERY quiet.
Intel have more bugs than AMD, it just so happens that AMD are more open and forthcoming with both negative and positive information whereas Intel are simply biased towards good press.
This has pretty much been the de facto standard for the past two decade.
Agreed
There is a reason for the double standards- AMD can't afford to make mistakes, Intel can.
Any word on the updated SB700?
