- 27 Jul 2005
- The Orion Spur
Purely theoretical of course as I imagine the infrastructure to implement this kind of system would be very complex.
Do you think the amount you get fined should be set according to how much you earn ?, I can't help feeling that it would be the most fair thing to do really because the effect it has on a low-income earner is greater than a high earner so simply put the punishment that either class (low/mid/high) endures because of their mistake is not the same, take prison for example, rich or poor the punishment is equal, you both have to endure that same conditions for the same period of time, perfectly fair, but the effects a small fine can cause on a low income earner compared to a high income earner can be drastically different, I've seen some good people with family's suffer hard because of fines, for some it can change their lives, for a high earner the fine is the same but the punishment is not,
what are your thoughts on this.
