PC spec
Asus M2N32 WS Pro nForce 590 SLi Socket AM2 ( BIOS updated to 1703 )
AMD AM2 Phenom 9600+ quad core cpu
OCZ 4GB (4x1GB) PC2-8500C5 1066MHz SLI-Ready Edition Dual Channel DDR2
2 x BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI PCI-Express in SLI
Enermax Galaxy 1000W EGX1000EWL ATX2.2 Modular PSU
2 x Western Digital Caviar SE16 500GB SATA-II 16MB Cache - OEM (WD5000AAKS)
The whole system works fine and stable when i use my AMD FX-62 Dual core 2.78
System problem
Ive just upgrade the the cpu to the phenom 9600+
But the system freezes up as the system boots
If i try entering the bios it also freezes as i enter the bios setup
I also get blue screen of death every time i try to boot the system
I sent the chip back for testing to OCUK but they say the chip is fine
So ive cleared the cmos run bios in default settings
Re-flashed the bios again incase of bad update but seems fine
Ran the system in barebones I.E.
1 and 2 sticks of ram
One graphics card one hard drive
Still the system blue screens and freezes
Ive run out of ideas now anyone got any idea or had the same problem ?
Thanks EnCoDeR
System problem
Thanks EnCoDeR
