Yeah, 1TB sorry. Why would it be hard to backup? I suggested RAID 10, speed and redundancy.
get back in yer pen![]()
Go away Glen, shouldn't you be drooling at something over on the AV forums?
watercooling is out the question ... been there done that ... too much argro.
cheers guys you have certainly given me some food for thought...
one last question, if i end up doing a uturn and re-ordering a mac pro again, how easy is it to set up raid config ( never do anything like that on a mac before )
Spec of the mac pro i have in mind is:
Two 3.0GHz Quad-Core Intel Xeo
4GB (4x1GB)
ATI Radeon HD 2600 XT 256MB
500GB 7200-rpm Serial ATA 3Gb
1TB 7200-rpm Serial ATA 3Gb
One 16x SuperDrive
APPLE WIRELESS MIGHTY MOUSE
WIRELESS KEYBD/ OS X-GBR.
Country Kit-B
is this your profession or hobby?
Hiya everyone,
Am looking to purchase some components for a new system i intend to use as a Digital Audio Workstation (Music Production). I usually have no problems picking out the right components and building my own system, however after reading tons of reviews on quad core intels, motherboard and ram - it literally has got my head spinning.
I was wondering, if i give you a budget of £3,000 +/- £300, would you recommend the best spec i could get for that price. I only need a bare bones machine, no monitor or soundcard is needed.
As this system is for a DAW, i need noise to be at a minimum. So the quieter the better.
I'll start the spec off :
* Intel Quad QX9650
* mobo ?
* 4 Gig Ram of ?
* ATI Radeon HD 2600 XT
* Seagate Barracuda 1 x 1TB
* Seagate Barracuda 3 x 750 or 500GB
Whats the difference between the ES.2 and the 7200 ?
What power supply / case do you recommend ? - quieter the better
Thanks for your time ....
Vinney.
you want to spend that much, and only want a 2600XT![]()
no its about you not thinking. Where is your evidence that a 3850 would use less power then a 2600xt ?
Hes not going to be gaming by the sounds of it and id imagine the most graphical use the pc would get would be watching videos which he has perhaps compiled with the music etc. Nothing heavy, why waste the money?
