- 29 Jun 2005
- London
Decided to grab a cheap Kood R72 to start off with, if I get to grips with IR, then I'll likely fork out for a Hoya, but this will do in the meantime.
I'm going to take it out at the weekend, I'm visiting my mate in a leafy area of Hemel Hempstead, so should get the chance to at least test it all out.
I mucked about with it a bit yesterday, but was only in my room, which is poorly lit (it was dark outside), so I could only get a quick go at setting the white balance, which proved to be pretty easy, although the low level of artificial light meant I had to go to 30sec exposures at full aperture for any sort of decent image in the end.
I assume that proper sunlight will afford a much higher level of IR for me to work with, but what sort of rough exposure times will I be looking at?
Also, how do I go about focusing?
I just get a black (well, v dark red!) blank image on the viewfinder of my Fuji S9600 with the filter on, should I be able to see a bit better when I'm working in sunlight?
Next purchase will obviously have to be a tripod, which I currently dont have, so that'll be rather limiting!
Any tips on a cheap, compact one to get me started?
