- 18 Oct 2002
- Nr Colchester, Essex
I bought 2 x Geil 2GB 6400 Kit's a while back (2x1GB) and they will not work with my AW9D MAX using the 1.5 or 1.6 bios. They don't work at all, not even one of them on it's own, I have to use bios 1.3. The Problem here is 1.3 will not run vista with my Q6600, it just hangs on install. Even if I install with 1.5 and swap back to 1.3 it won't boot.
So I either need some new ram that is compatible or a new motherboard that is compatible. I am thinking a new board as I max the Q6600 out at 2.7ghz on this one so I will get a bit of a boost.
I have:
Q6600, 4 x 1GB Geil 6400 CAS4, ATI HD3870. I also need Firewire support, and I intend to clock it as far as it will go.
I was going to go for an X38 board, but are they really worth the extra? From what I have read they don't really allow for any better overclock than the P35.
Not sure which board to get really. a £70 P35 a £120 P35 or £130+ X38. There doesn't seem to be a clear favourite like there usually is.
Does anybody now which will work with that memory?
Thanks
I have:
Thanks
