if 1:1 scaling is good, out of the Dell`s 3008WFP supported resolutions, how low would be too low for comfort?
Preset Display Modes:
VESA, 720 x 400 – 31.47 kHz Horizontal, 70.0 Hz Vertical, 28.3 MHz
VESA, 640 x 480 – 31.47 kHz Horizontal, 60.0 Hz Vertical, 25.2 MHz
VESA, 640 x 480 – 37.5 kHz Horizontal, 75.0 Hz Vertical, 31.5 MHz
VESA, 800 x 600 – 37.88 kHz Horizontal, 60.0 Hz Vertical, 49.5 MHz
VESA, 800 x 600 – 46.88 kHz Horizontal, 75.0 Hz Vertical, 49.5 MHz
VESA, 1024 x 768 – 48.36 kHz Horizontal, 60.0 Hz Vertical, 65.0 MHz
VESA, 1024 x 768 – 60.0 kHz Horizontal, 75.0 Hz Vertical, 78.75 MHz
VESA, 1152 x 864 – 67.5 kHz Horizontal, 75.0 Hz Vertical, 108 MHz
VESA, 1280 x 800 – 49.7 kHz Horizontal, 60.0 Hz Vertical, 83.5 MHz
VESA, 1280 x 1024 – 64.0 kHz Horizontal, 60.0 Hz Vertical, 108 MHz
VESA, 1280 x 1024 – 80.0 kHz Horizontal, 75.0 Hz Vertical, 135 MHz
VESA, 1600 x 1200 – 75.0 kHz Horizontal, 60.0 Hz Vertical, 162 MHz
VESA, 1920 x 1200 – 74.6 kHz Horizontal, 60.0 Hz Vertical, 193.5 MHz
VESA, 2560 x 1600 – 98.71 kHz Horizontal, 60.0 Hz Vertical, 268.5 MHz
