- 14 Dec 2007
done by a normal user, not me, not ES.
if you set FSB without locking the RAM speed and SPD beforehand (e.g. 667MHz, 5-5-5-15, 1:1....etc),
definitely fail will be the result.
It went straight up to this straight away with voltages increased as you can see. But anything above about 360FSB and it is unstable =/
Ultra Low Latency = Lower overclocking power, if you don't loosen the timings and increasing the vdimm.
hi there, timings were slackend and the board wont post after 230FSB im using geil ram so i upped the ram volts by 0.20 as it defaults at 1.88 and the geil says it runs between 1.9-2.2 but still no differance.
i have tryed an fsb of 250 wich should be no trouble atall with every ram divider possible and it still wont post above 230 and ive tryed 260, 270, 280, 290 and so on with differant divider settings i even upped the cpu voltage but at 250Fsb that shouldnt really be needed should it though it maid no differance any way.
this is all about BIOS settings.....
you should have seen users here are able to oc with Duo & Quad.
for easy reference and comment,
please upload some BIOS screen shots, like CPU, DRAM, Voltage settings.
so that we can help you.
@kenofstephen
Any news of the new bios??
Have you tried just resetting the BIOS to optimum defaults and turning the FSB up to 266? This BIOS is not very clever, but on default it seems to clock pretty well. I get most of my best overclocks on this by just leaving everything set to default.
The one on the website is v1.2 the bios the ocuk boards ship with currently.
Ideal thanks for the reply.
Any idea how well one of these will cope with an e8500 Kenofstephen ??
Hi there will take some photo's of the bios screens soon as i can but i have loaded optamized defaults around 4 times now and even had to reset the bios with the mainboard jumper on a couple of occasions.
each time i try to overclock the cpu i will start with simply upping the fsb to 250 to start with then i set the ram voltages to +0.20v as the geil ram is rated for between 1.9v-2.2v. If this has no luck i slacken the timings on the ram to 5-5-5-15 with the previous settings, and if that does not work i go through and try to boot it each time with each memory divider in turn eliminating a divider wich is just plane wrong. to be hounest the divider looses me im more acustomed to a gigabyte bios though i do know enough about overclocking that this board should be a doddle as i have to deal with overclocking a g33m-s2 with a e2140 and frankly down rite louzy overclocking elixer ram.
that combination is still serving me now and seems like a dodle to this p35 board, one thing i have noticed though is that the razer diamondback and the eclipse II keyboard indicate a bad overclock on this board. by this i mean that if the machine starts to boot the keyboard and mouse flash and light up as usual but then they just go off and no blue lights to see and this is the first indication of a bad setting somewere so its a restart and it boots at default.
a nice feature to add to the bios would be a real time ram and cpu calculation in the bios showing you what your settings are going to result in after reboot. just a suggestion that last bit as it seems like a feature that should be on any board that boasts overclockability.
WOOT, I'll flash my BIOS when I get home from college today, and let you know how it goes.
Though I'll be doing a software flash (never done a dos flash in my life and dont want to start now)
