DSL router to ADSL router.
25 Jul 2006
Hi, not too good with networks as I just have a simple setup. :)
But a friend of mine has an old ADSL wireless router he wants to use to get his Wii online.
Basically he has Virgin Media for his broadband supplier, connecting the Virgin modem to a wired dsl router. But the Wii is downstairs and they can't wire the Wii into the router. So is it possible to connect the dsl router, to the adsl wireless router so the Wii can get online?
Hopefully the above makes sense.
Cheers mr.sly :0
If you have spare ports on the cable router, then just plug a cable in to that and the ADSL one.
Will have to configure the wireless on the router etc then it should work. Basically using the ADSL router as a basic Wireless access point.
Yes, you just need to turn off the DHCP server on the ADSL router (as otherwise there'll be two running which will cause issues) and also assign it an IP address within the same subnet as the cable router. For example, assuming the cable router is 192.168.0.1 then the ADSL router should be given an address in the same range, like 192.168.0.2 so it can be managed. Then just set the wireless side of things up as normal.
Once that's done just plug one of the ADSL router's ethernet ports into the cable router. The ADSL router will just be acting as a simple switch and wireless access point, with no routing happening.
Cheers, that makes sense with my limited knowledge of networks. Will be trying it out tonight so hopefully it'll be plain sailing.
Cheers guys. :)
The IP of the ADSL router doesn't have to be in the same subnet, but it's useful if you need to configure it - because you're going to enable encryption on it, aren't you :p
