Does Jailbreak void warranty?
30 Aug 2004
Sheffield
Hi All,
As the title says, does it?
I'm getting an iPod Touch for my birthday, and I want to Jailbreak it, but I don't want to void the warranty ...
Sorry if this has been asked like a million time, I looked, but couldn't find any reliable information regarding warranty.
Cheers
I dont mind walking you through the process mate once you get it.
Takes around 15 minutes to do, then a good few hours messing around with the new stuff you can do. :)
If you want to watch videos as well, then these two are the best:
(part 1)
(part 2)
(part 3)
Basically he goes through every step in as much detail as possible so the videos are like 15 minutes in total, but in reality once you know how to do it, it takes probabily 6 or 7 minutes to do from scratch. :)
cheers OzZie :)
i'll take a look at the videos, and if i'm still unsure i'll take you up on your offer :)
is it worth doing then? i don't even know what you can do once it has jailbreak on it, all i know is you can install 3rd party apps, and everyone seems to be doing it :)
Yeah most of them, it will tell you if not, or it will be obvious if it is iPhone only.
Sketches makes everyone go "wow", it's an etch a sketch, so draw something shake the iPod to erase it.
There's loads of things that use the accelerometer which is impressive :)
cool, is there a centralised website with all / most of the jailbreak applications on it? if so, anyone have the link? (as long as it doesn't break any forum rules?)
cheers, the suggested apps look cool :D can't wait for my iTouch now! :p
changed my mind, think i'm gonna get an iPhone now :D
i'm due a new phone anyways! :p
EDIT: what does o2 mean by unlimited UK data? does it mean i can look at as many sites etc as i want using EDGE? or just wifi hotspots?
Yeah with EDGE, good choice on the iPhone mate :)
But there is a fair usage policy, can't remember what it is though as I use PAYG in mine.
