just arrived..my personal review of 3870x2
Gerard: Any clue which manufacturer does the 6-pin to 8-pin converter in the box then? OCUK doesn't even sell the adapters from what I can see.
Firstly contact ocUK in case it was mislaid or something, then give ATi a prod they are likely to send you one for free
I lost my dvi->vga dongle on a 1950xtx and they sent one for no charge a while back :x
Just bit the bullet on an HIS HD3870 X2 from OCUK. Managed to find a 6-pin to 8-pin connector on a famous auction house, just to be on the safe side - little bit pricey though (£14.99 for a connector!).
Or make one. Only two earth wires.
I wouldnt go with them if i were you. the connectors arent very good and found personal experience I havent been sent one that worked before.
Plus £14.,99 for an adaptor :eek::eek::eek:
Is it made of gold?
I installed the crysis demo and tried the benchmark, using the settings in the ocuk thread i got the following:
With cat ai set to standard i got 34.7fps, with it set to advanced i got this
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
30/01/2008 17:29:57 - Vista 64
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 45.1
Kudos. :) Unfortunately my electrical skills would guarantee that I would blow up the card and everything else in my room if I tried anything like this, so £15 is an acceptable burden to bear.
Perhaps consider selling your existing PSU, and getting one with an 8-pin already on it? If the difference is about £15 then it might be worth it :)
45fps. Nice :) Pretty much inline with the other review. Good news is that apparently the new driver as seen by places like hardocp increase performance a significant amount, so something to look forward to :)
Also.. does the cat ai actually make any visual difference that you have noticed?
Matthew
Matthew
No visual differences i could spot :)
